ZedBoard Hardware Design how to write independent HDL code?
  • Subscribers 359 subscribers
  • Views 323 views
i have a zc702 board,there is a bit file run in sdram independent,when i use planahead,i need bulit a XPS project and import it to the planahead and generate a bitstream,then export hardware,at last bulit a c project and write controll signals, createimage zynqfsbl+bitstream file+myproject and programming it to the qspiflash ,but this bit file can run independent in the sdram
    0 Former Member over 13 years ago
    tengshiyi1988,
    My apologies but I don't quite understand your question/problem.  Could you possible break it into pieces and/or ask in a different way?
    Jayson,
    I believe you meant to say that the PL and SDRAM are * volatile*, and thus will loose their contents on reboot.
    tengshiyi1988,
    Did Jayson's answer help you?  Are you moving forward with your board?
