ZedBoard Hardware Design zedboard(Reference design for Zedboard and AD-FMCOMMS2-EBZ)
  • Subscribers 359 subscribers
  • Views 582 views
I encountered a problem when i generate the bitstreem of  Reference design for Zedboard and AD-FMCOMMS2-EBZ with PlanAhead14.4.The problem is:ERROR:EDK:2951 -
   Unknown Tcl procedure ::hw_axi_ad9361_v1_00_a::run_coregen called
ERROR:EDK - axi_ad9361_0 (axi_ad9361) -
INFO: No asynchronous clock conversions in axi_interconnect axi_interconnect_2.
INFO: No asynchronous clock conversions in axi_interconnect axi_interconnect_3.
ERROR:EDK:440 - platgen failed with errors!
make: *** [implementation/system_processing_system7_0_wrapper.ngc] u00B4u00EDu00CEu00F3 2
ERROR:EDK -
Error while running "make -f system.make netlist".
ERROR: [Edk 24-166] (generate_target): Failed to execute XPS script. Please check for any errors reported by the XPS application in the console: [D:/Zedboard/sdr14_4/cf_ad9361_zed/__xps/pa/_system_synth.tcl]
My design tool version is ise14.4,and i download the HDL design from  http://wiki.analog.com/resources/eval/user-guides/ad-fmcomms2-ebz/reference_hdl.
Any help you can provide will be much appreciated.
Thanks!
    Hi I am having the same issue. did you get the chance to resolve it?
    Ahmed,
    0 Former Member over 11 years ago in reply to Former Member
    As for the TCL error, if you have successfully generated the netlists, just comment out this line in the MPD file.
    OPTION PLATGEN_SYSLEVEL_UPDATE_PROC = run_coregen
    Form ADI support
    Ahmed,
