ZedBoard Hardware Design FMC-IMAGEON-Vita Pass-Through design
  • Subscribers 352 subscribers
  • Views 217 views
I am working with the FMC-IMAGEON-Vita_mono Pass-Through basic design. I have remove the DPC block as a result of licence problems and it works perfectly.
My problem cames when I try to connect something between the Video-to-AXI block and the Y-to_Y22 block.
If I try to create a pass-through core with Sysgen and export it as 'IPCatalog, I am not able to see anything on the screen. And if I use a IP Core from Xilinx (I have try the gamma correction block), my output is green or green/pink...
Has someone an idea of where I am making the mistake?
Thanks a lot in advance.
