ZedBoard Hardware Design document for Basic Vivado IPI Design
  • Subscribers 358 subscribers
  • Views 415 views
HI There,
Every reference design includes a document for illustration of the design. But for reference design of Basic Vivado IPI Design, I didn't find any doc in Basic_IPI_Design_ZedBoard_2013p2.zip.
Is there any doc for this design?
Where can I find the document for this design if there is.
Thx
Sam
  • drozwood90
    0 drozwood90 over 12 years ago
    Sam,
    Please note that this was meant as a reference design, not a tutorial.  So, it does not have a document.  On the download page, there is a description:
    http://www.zedboard.org/design/1521/11
    The design consists of a Zynq subsystem and I added (3) single channel soft GPIO peripherals to interface to the:
    - 5 buttons
    - 8 switches
    - 8 LEDs
    There is an SDK peripherals_test application that reads back the buttons and switches and reports the button and switch values in the terminal (115,200 baud).  It also cycles the 8 LEDs long enough to see them (~20 iterations).
    A way to see the Block View of the project is under Flow Navigator.
    Under the IP Integrator Flow, you can open block design, chose design_1.bd.
    Vivado will then open and show you the Block Diagram View of the design.
    If you need more information, please let us know.
    --Dan
