ZedBoard Hardware Design petalinux
  • Subscribers 359 subscribers
  • Views 492 views
petalinux
Hi
I want to install Linux on a Zedbaord. I've downloaded:
http://zedboard.org/course/petalinux-zynq%C2%AE-7000-all-programmable-soc?sid=69111
and tried to run thro chapter 1. Very quickly I run into issues with missing files etc.
I'm currently using Vivado 2015.1 is there a tutorial that currently guides me thro the installation that works.
Regards
Peter
    Peter,
      Have you looked at Xilinx UG1144?
      Alternately, under the Mini-ITX Reference Designs, there is a 2014.4 PetaLinux tutorial that has a section on installing the development environment.   Between those two guides there should be sufficient information to get you up and running.
    Ron
    0 Former Member over 10 years ago in reply to Former Member
    I keep running into the same problem and that is I need a Linux host workstation  (PetaLinux requires a number of standard development tools and libraries to be installed on your Linux host workstation). I have a windows based host work station. Is there not a way of doing it from a windows PC?
    PetaLinux can only be installed on a Linux host system.  If you want to do it on a Windows host, the easiest thing to do is to download a VM platform like VirtualBox and install a Linux OS on that.
    Ron
