ZedBoard Hardware Design Access to  DDR by IP
  • Subscribers 359 subscribers
  • Views 334 views
Access to  DDR by IP
100mokhtar
100mokhtar over 13 years ago
Hi all,
Beginning, I created a custom peripheral (with CIP XPS) and  I used the 32 GP AXI Master to connect the PS with my accelerator in PL (AXI-Lite). The data is sent from PS to PL, then traitemnt is done via the hardware accelerator, finally the data returned from PL to   PS :
       unsigned int Tab [4];
       *r0=   Tab[0];
       *r1=   Tab[1];
       *r2=   Tab[2];
       *r3=   Tab[3];
       Tab[0] =   *r0;
       Tab[1] = *r1;
       Tab[2]= *r2;
       Tab[3] = *r3;
And I got a correct result.
Now, since the data is stored in the DDR, I want that my accelerator uses the high performance (HP) 64 bit slave port to directly access to DDR. So, I created a custom peripheral (with CIP XPS), I choose AXI4 burst capable high-throughput memory mapped interface. After that, I connected the slave of my IP to AXI-Lite Master of PS and the master (64 bit) of IP to the HP slave port of PS.
The problem that I can't found any solution or tutoral wich explain how I send  the adress of the Tab which allow to the IP to access to ddr. How the PL can access directly to the data of Tab??
Any help please??
Moktar.
  • 100mokhtar
    0 100mokhtar over 13 years ago
    I forgot, r0, r1, r2 and r3 are software register.
