ZedBoard Hardware Design Zedboard J1 and J2 positions
  • Subscribers 359 subscribers
  • Views 469 views
I am trying to design an FMC daughterboard for the zedboard which will also plug into the XADC header, but am having a bit of trouble determining exactly where to place the connectors on the PCB. the mechanical drawings have a measurement of the Y position of the FMC connector J1 but nothing for its X position, and no measurement at all for the XADC header J2. I could measure from the gerbers but they're provided in PDF form.
If someone could provide the XY positions of those two connectors on the zedboard that would be awesome, if not I suppose I can just use a ribbon cable to connect to the XADC header.
Thanks!
    Unless you can use the 3D or STEP models posted on the ZedBoard documentation page to determine the positions we don't have any other documentation we can provide for the connector position except for the layout files you mention.
    -Gary
  • bhfletcher
    0 bhfletcher over 10 years ago
    You can request the actual gerbers through your local Avnet FAE.
    Bryan
