ZedBoard Hardware Design New device with IO ports
  • Subscribers 359 subscribers
  • Views 325 views
I am creating a new peripheral on PS. This module writes on LEDs value written by application (SDK) that is why I need to add to my peripheral a new output to connect it to LED. I am creating my project using PlanAhead, how can I configure this output while creating this module on u201CXilinx Platform Studiou201D?
Thank you everybody,
Najem
    0 Former Member over 13 years ago
    Hi Najem
    If you want to run the application from Linux, UG873 has what you're after in chapter 9.  They make a counter, but you should be able to adapt it to your needs easily enough.  If you want to run it as a standalone application the same procedure applies for the hardware design, just use Xil_Out calls to write to the device.
    UG873:
    http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_3/ug873-zynq-ctt.pdf
    Hope that helps,
    Matthew
    0 Former Member over 13 years ago in reply to Former Member
    Thank you Matthew for your answer. I was working on bareMetal mode without Linux but now it is working.
    Best regards,
    Najem
