ZedBoard Hardware Design ARM Processor Not Detecting in Hardware Manager
  • Subscribers 361 subscribers
  • Views 1158 views
Hello when i am trying to load the program through USB Jtag (micro USB Connector) i am seeing only ZC7020 but not the ARM Processor in the scan chain.
i am using Zedboard.
Please help me to solve this issue.
i had raised the webcase in Xilinx and did not get the solution for the same.
Please help me at the earliest.
Thanks and Regards
Prakash G
    Hi Prakash,
    Did you install driver cable ??? it might be this the problem of recognizing.
    kind regards.
    Anisse B
    Hello Prakash,
    You might also want to check and make sure that Jmper JP7 is set to '0' to select Cascaded JTAG mode.
    -Gary
    Hello
    I had made sure that the jumpers and the drivers are fine.
    i have two boards one of them is working fine and the other is having the problem.
    i had checked from the WTS Team from Xilinx and made sure that jumpers and the drivers for Zed Board is in tact.
    I am sure the problem is in the hardware but not able to check it.
    the board is not under warranty.
    hence reply for the same will be fine.
    Regards
    Prakash G
  • marzhan
    0 marzhan over 9 years ago
    Hello everybody here!!!  my computer recognized jtag port but the problem it couldnt find ARM through Jtag cable, I've done installation of cable drivers cypress , so could you tell me is that related to board?
  • jafoste4
    0 jafoste4 over 9 years ago
    Hello Marzhan,
    Are you using a ZedBoard, and have you followed the suggestions above? Which version of SDK are you using? Are you set to JTAG Boot?
    Here are some other references you should look through.
    https://forums.xilinx.com/t5/Embedded-Processor-System-Design/Zynq-not-detecting-ARM-system/td-p/331561
    https://forums.xilinx.com/t5/Embedded-Development-Tools/SDK-not-recognizing-arm-core/td-p/677282
    --Josh
