ZedBoard Hardware Design Recovery for ZED board from Debug Mode
  • Subscribers 360 subscribers
  • Views 678 views
satishkumar
satishkumar over 10 years ago
Dear all,
I am working on applying different Debug Techqunies on ZED board,I went to Debug mode &  had resterd the board, but it is not booting as usual,  as it is not came from debug mode to normal mode.
Can you guys please help me, how to recover the board.
Thanks & Regards,
Satish.G
    Hello Satish,
    Can you give us a little more information. I am not sure what you are referring to when you say 'Debug mode".
    Are you using Linux or some other OS or just trying to use the SDK debugger?
    Are you trying to boot from JTAG, SD Card, or QSPI Flash? Are the boot jumpers set correctly?
    Can you boot a known good image?
    What version of Xilinx tools are you using? What is your host PC OS?
    -Gary
  • satishkumar
    0 satishkumar over 10 years ago in reply to Former Member
    1. I am using Linux, with SDK debugger
    2. I am trying to boot through JTAG debugger
    3. Yes Image is good/working Image.
    4. Xilinx tools are 2014.4 & host PC OS: ubuntu 12.04 on Dell Inspiron
    Thanks & Regards
    Satish.G
    Hi Satish,
    I don't believe the SDK Debugger works that way. If you reset your board, and the boot jumpers are set to JTAG, it will wait to be initialized. The SDK debugger will need to be restarted at this point and will need to run the ps7_init.tcl again. And if you have anything in the PL (Programmable Logic) in your design you will need to load the FPGA bitstream again as well.
    You can test this with a simple 'hello world' type bare metal design.
    -Gary
  • satishkumar
    thank you gary.
    I will try booting simple Hello world stuff.
    Thanks & regards
    Satish.G
