ZedBoard Hardware Design Extended MIO to connect ports in to uart
  • Subscribers 359 subscribers
  • Views 522 views
I am working on a design and i developped my own uart. I want to implement my design in standealone mode (without ARM processor). I need to connect my component on to serial port (RS232) from the zedboard. I found that i should use Extended MIO to connect ports from PL to the usb-to-uart bridge. But i am not able to do that. I don't know how can i use Extended MIO to configure the bridge.
Any help please ?
Thank you,
Najem
    Thank you for your response,
    So you mean that i can not connect my own uart to the usb-to-uart bridge and use the usb to connect it to my PC ?
    When i used Virtex5 for example, i connect it to my PC via RS232. But my probleme here that in zynq i don't have an RS232 connector so i have to pass via usb or other I/O port.
    Najem
    Hello again,
    I think i had got the idea. I have to use the PMOD to interface my uart to Zynq. Then I can use the Pmod rs232 to connect it to my PC. That is right ?
    Thank you
