ZedBoard Hardware Design Implement EMC controller on FMC connector
  • Subscribers 358 subscribers
  • Views 342 views
I implemented Zynq+Interconnect+EMC controller on FMC connector, and try to access NOR flash by UART port. e.g. using "mw 0 1" to write data to Flash memory. But it's failed and there is no output on FMC port. I used same way to implement GPIO module and access onboard LED successfully. Would you help?
BTW, there is no design guide or doc of ZedBoard, so I'm using Xilinx Zynq7000 EPP design guide. Is there any significant difference between Zedboard and Xilinx ZC702 board?
  • bhfletcher
    0 bhfletcher over 13 years ago
    The design methodology for ZC702 and ZedBoard are the same, so referencing all the Xilinx Zynq-based docs is recommended.  ZC702 and ZedBoard both have the 7020 device.  There are some other differences (ethernet phy, USB phy, qspi flash), but I wouldn't expect any of those to affect your FMC design.
    To clarify, you have an FMC with NOR Flash.  Which EMC are you using?  How are connecting to the FMC, which is on the PL?
    Bryan
