ZedBoard Hardware Design Xilinux LED control
  • Subscribers 359 subscribers
  • Views 321 views
Xilinux LED control
deaxman
deaxman over 12 years ago
When I try to set PS_GPIO[8] in Xilinux (W22 location, which should be an LED light) it says that there are conflicting signals.  This makes sense as PS_GPIO is set in Xillydemo (the code that is used with your own code to write values to the files on linux).  Here is how it is written to:
// General signals
    .PS_CLK(PS_CLK),
    .PS_PORB(PS_PORB),
    .PS_SRSTB(PS_SRSTB),
    .clk_100(clk_100),
    .otg_oc(otg_oc),
    .DDR_Addr(DDR_Addr),
    .DDR_BankAddr(DDR_BankAddr),
    .DDR_CAS_n(DDR_CAS_n),
    .DDR_CKE(DDR_CKE),
    .DDR_CS_n(DDR_CS_n),
    .DDR_Clk(DDR_Clk),
    .DDR_Clk_n(DDR_Clk_n),
    .DDR_DM(DDR_DM),
    .DDR_DQ(DDR_DQ),
    .DDR_DQS(DDR_DQS),
    .DDR_DQS_n(DDR_DQS_n),
    .DDR_DRSTB(DDR_DRSTB),
    .DDR_ODT(DDR_ODT),
    .DDR_RAS_n(DDR_RAS_n),
    .DDR_VRN(DDR_VRN),
    .DDR_VRP(DDR_VRP),
    .MIO(MIO),
    ***********//.PS_GPIO(PS_GPIO),***********
    .DDR_WEB(DDR_WEB),
    .GPIO_LED(GPIO_LED),
    .bus_clk(bus_clk),
    .quiesce(quiesce),
Here I have commented that line out.  Is there a better practice than this?  I am having trouble tracing where that line is connected.  Thanks!
-Dustin Axman
    Could you please elaborate what it is you attempted to do, and what error message you got? What do you mean with "try to set PS_GPIO[8]" and who and how "it says" there are conflicting signals?
    Best,
       Eli
