ZedBoard Hardware Design HDMI Display Controller Tutorial does not meet timing
  • Subscribers 358 subscribers
  • Views 339 views
I am going through the "ZedBoard - HDMI Display Controller Tutorial - 2013.3" pdf document and following it exactly, using Vivado 2013.3. The document is here:
http://zedboard.org/sites/default/files/design/ZedBoard_HDMI_Display_Tutorial_2013_3_20140325%281%29.zip
When I generate the bitstream, it runs synthesis and implementation but generates 5 critical warnings, including "design does not meet timing".
Here is a screenshot with the warnings: https://i.imgur.com/fyrdx2N.png
And the timing summary is here: http://w.0bl.net/timing_report.txt
How can I fix these issues?
  • albertabeef
    0 albertabeef over 12 years ago
    Brad,
    I just went through the tutorial and you are correct.
    The XDC constraints file contained a typo.
    Please modify the following line:
       create_generated_clock -name hdmio_clk [get_pins tutorial_i/clk_wiz_0/U0/mmcm_adv_inst/CLKOUT0]
    with the following correct constraint:
       create_generated_clock -name hdmio_clk [get_pins tutorial_i/clk_wiz_0/inst/mmcm_adv_inst/CLKOUT0]
    Note that "U0" was changed to "inst" in the hierarchy path for CLKOUT0.
    Hope this helps !
    Mario.
