ZedBoard Hardware Design Clocking Wizard Timing Error (TPWS<0) when output frequency >460MHz
  • Subscribers 358 subscribers
  • Views 604 views
e14 Contributor over 7 years ago
I have created a project where in the block design there is only one input port, a clocking wizard block and an output port.
The input clock of the clocking wizard (CLK_IN1) is the sysclock.
When the output frequency is higher than 460 MHz there is a timing error after the  implementation (TPWS<0) in both cases: PLL and MMCM.
Is it possible to generate a 640 MHz clock with the clocking wizard using as input the 100 MHz sysclock?
Thank you in advance!
  • bhfletcher
    0 bhfletcher over 7 years ago
    Hello @alejandroB,
    Were you able to resolve this problem? I am curious what the solution was. I did find this information, which is for a different architecture than Zynq-7000, but may still be relevant.
    https://www.xilinx.com/support/answers/34937.html
    This one may also help -- https://www.xilinx.com/support/answers/46504.html
    Bryan
