ZedBoard Hardware Design Minimum Operation Temperature of ZedBoard
  • Subscribers 359 subscribers
  • Views 586 views
I am trying to see if somebody has powered up the Zedboard at -20degC and have it working reliably.
I was able to power up the Zedboard with the boot files which came with it at -10degC and it did boot up, but once I saw that the PL was not programmed (the blue LED did not light up).
Since my application needs to work at -20degC and +50degC do you guys see any issue with me using it at these temperatures and will I be significantly reducing the device life span.
  • bhfletcher
    0 bhfletcher over 12 years ago
    ZedBoard was not designed to support this temperature range. The primary issue are the temperature grades of the populated devices. For example, the Zynq is a C-grade device, which is 0 to 85 C.
    Is this an experiment or are you creating a product? Depending on what your scenario is, we might have some different suggestions for you.
    Bryan
    I am trying to create a product. The project is in experimental stage
  • bhfletcher
    If there is anyone else needing a Zynq development board with I-temp devices populated, please contact me privately.
    Bryan
  • bhfletcher
    0 bhfletcher over 12 years ago in reply to bhfletcher
    The MicroZed is offered with I-grade devices.
    AES-Z7MB-7Z010-SOM-I-G
    AES-Z7MB-7Z020-SOM-I-G
    Bryan
