ZedBoard Hardware Design Zedboard XPS settings
  • Subscribers 360 subscribers
  • Views 631 views
mariem_@fsm.12-34
mariem_@fsm.12-34 over 8 years ago
I wonder If I have to predownload does the XPS settings for the zedobard's Design (Definition File and Master XDC File). Thanks in advance?
  • jafoste4
    jafoste4 over 8 years ago +1 verified
    Hello, The board definition file for Zedboard comes pre loaded within Vivado, so you do not need to download and install it into your Vivado version. However, the master constraints are a diffrent story…
  • jafoste4
    Hello, Please take a look at this resource to familiarize yourself with constraints. https://www.xilinx.com/support/documentation/sw_manuals/xilinx11/ise_c_using_design_constraints.htm --Josh
  • jafoste4
    0 jafoste4 over 8 years ago
    However, the master constraints are a diffrent story, you will need to download them from the document page related to Zedboard and then import them into your project if you wish to use them.
    Josh
  • mariem_@fsm.12-34
    0 mariem_@fsm.12-34 over 8 years ago in reply to jafoste4
    Hi JFoster,
    Can you clarify , in which case I have to import the master constraints to my project?
  • jafoste4
    --Josh
