ZedBoard Hardware Design best terminal programs for windows 10 and zedboard
  • Subscribers 359 subscribers
  • Views 614 views
hdlgeorge
hdlgeorge over 10 years ago
I have tried using tera term to perform the getting started instructions. The terminal window is filled with garbage, I get the image on the display but the terminal does not communicate with the board.
I am an hdl asic designer and have not in the past dealt with boards or software. All I want to do is go(in 32 bit chunks) from/to the windows 10 computer thru the programmable system eventually to the programmable logic fabric.
Thanks George
  • albertabeef
    0 albertabeef over 10 years ago
    George,
    Usually, when there is garbage in a serial console, it is caused by incorrect baud rate setting.
    Please verify that you have the baud rate set correctly.
    For Zynq designs, this should be set to 115200.
    Mario.
  • hdlgeorge
    0 hdlgeorge over 10 years ago
    Mario
    It works. tera term never let me see a baud rate.
    tyhanks George
