ZedBoard Hardware Design ZedBoard Operating Temperature
  • Subscribers 359 subscribers
  • Views 720 views
For a research project, I need to heat the Zynq chip of the ZedBoard, using a temperature-controlled chamber. The idea is to heat up the board in a certain range of temperature to analyze the effect on a design. The temperature would be increased by 5u00BAC every 15 min to wait for stabilization and to avoid any thermal shock.
Here is the issue: What is the operating temperature range of this board ?
I didn't find this information in the documentation provided.
Thank you for helping!
    The ZedBoard is a development board targeted for use in a controlled lab environment. While it does not have a specified temperature range similar boards, such as the Xilinx ZC702 board, are specified to operate from 0 to +45 degrees C.
    If you need a Zynq board with a specified operating temperature range we offer the MicroZed and PicoZed boards with both 0 to +70 degree C and -40 to +85 degree C (Industrial Temp) versions.
    -Gary
