ZedBoard Hardware Design Stuck at address pointer initialization
  • Subscribers 361 subscribers
  • Views 529 views
2giglove
2giglove over 9 years ago
Hi all,
I am studying Zynq7000 using Zedboard.
I now try to bring up ug1165 tutorial using Zedboard, everything is fine until chapter 5: Using the HP Slave Port with AXI CDMA IP, with standalone application software.
When I run the application, it stops at line 355,
SrcPtr[((i+j))*(Index+1)] = Array_3[i][j];
This should be not hardware related issue, anyone has any idea?
Tutorial link
  • jafoste4
    0 jafoste4 over 9 years ago
    Hello 2giglove,
    Please post this question over at the Xilinx forum as they are the creators of this material and are responsible for supporting it.
    https://forums.xilinx.com/
    Thanks!
    --Josh
    0 e14 Contributor over 9 years ago
    Hello 2giglove, i have the exact same problem but i can't find your question at the Xilinx forum. Did you eventualy post the question there?
