ZedBoard Hardware Design Using basic sensors/ power output
  • Subscribers 359 subscribers
  • Views 407 views
dp3260
dp3260 over 7 years ago
I am new to using ZedBoards as a tool for projects, but an embedded design course I am taking uses it as our primary controller of various hardware devices (robot arm, etc.). We now have been tasked with a final project that simply must link hardware and software in a task. My group wants to write C/C++ code to input from a digital infrared sensor and provide output to an arm interface (we are given code and connector pins for this) as well as a basic water pump. My question is, how should I go about making the connections to the board for the input (from a digital signal) and the output to the water pump (only needs to be sent ~5V of power depending on a variable amount of time to function for this project).
Any advice/solutions would be helpful.
Thanks!
  • jafoste4
    0 jafoste4 over 7 years ago
    For educational support please ask your question over at the Digilent support forum.
    Thank you,
    Josh
