ZedBoard Hardware Design Dimensions to FMC connector
  • Subscribers 353 subscribers
  • Views 525 views
Can you tell me the dimension to the mounting holes of the FMC connector, from the nearest edge of the board? This dimension appears to be missing from the mechanical drawing. (i.e. Y=35.81mm and 98.81mm from the corner to the two mounting holes, respectively. What is the X value?)
  • zedhed
    0 zedhed over 13 years ago
    Hi TcPrentice,
    I think at one point we requested that this be added to the mechanical diagram for ZedBoard, but it looks like it did not get updated.
    I have both measured in Altium, so they should be fairly accurate:
    4.57mm from FMC mount hole center to PCB edge.
    7.62mm from FMC centerline to PCB edge.
    -Kevin
