ZedBoard Hardware Design Tutorial on a data bus and clock input into FPGA
  • Subscribers 358 subscribers
  • Views 538 views
henry10210
henry10210 over 10 years ago
Dear community, I am trying to handle up a sensor image in the FPGA.  In the past, I just dealt with a differential clock, and used just IBUFGDS without understanding what is going on under the hood.  I though I would have to instantiate IBUFG for a single ended clock now, and somehow phase shift the pixel data bus that the sensor is throwing at the FPGA, but I just read the section on IBUFG in UG768 (7series_hdl), which said: "Inference: Recommended", which I didn't know how to interpret.
Procesing a bus data that comes over along with an external clock must be a common task, so I hope I can find an applcation note on this topic.  Can anyone please point me in the right direction?
w/ regards,
Henry
  • drozwood90
    0 drozwood90 over 10 years ago
    Hi there,
    If you define the incoming signal as a clock, the tools will typically create all the proper logic - BUFG, etc. that is needed.  If you are having trouble here is an AR from Xilinx that might assist in forcing BUFG's to be used.
    http://www.xilinx.com/support/answers/19181.html
    --Dan
