ZedBoard Hardware Design FMC connector template
  • Replies 14 replies
  • Subscribers 361 subscribers
  • Views 2342 views
I'm about to start a new PCB using the FMC connector on Zedboard.
To save myself some work, i'm looking for a template, preferably in Altium, for an FMC daughter board. I basically just need the connector footprint, support hole positions and net names.
I looked around but could not find anything useful. Does anyone have a template?
Thanks in advance,
Mike
  • zedhed
    0 zedhed over 10 years ago
    Hi Mike,
    I don't think that we have a template but could you use one of the Altium PCB outlines from an existing FMC board?
    Take a look at this thread here which is along similar lines:
    http://microzed.org/content/dimensions-custom-board-area-microzed-fmc-carrier-card
    -Kevin
    0 e14 Contributor over 10 years ago in reply to zedhed
    Hi Kevin,
    I ended up rolling my own (Altium sch symbol with zed net names and foot print). If you have a repo somewhere, i can upload the template (after i tested it in our design).
    Mike
  • zedhed
    Hi Mike,
    I am glad to hear you found a way to move forward on this.  That is very nice of you to offer sharing this template back to us!
    I don't know if we have a repo for this stuff, but I can ask the hardware guys if there is someplace we can publish it.  Please let me know how your testing goes and PM me directly.
    -Kevin
    We found another thing in the "ZedBoard Master XDC Rev C/D v2 16.Apr.1" that is related;
    # FMC Expansion Connector - Bank 34
    set_property PACKAGE_PIN L19 [get_ports {FMC_CLK0_N}];  # "FMC-CLK0_N"
    set_property PACKAGE_PIN L18 [get_ports {FMC_CLK0_P}];  # "FMC-CLK0_P"
    set_property PACKAGE_PIN M20 [get_ports {FMC_LA00_CC_N}];  # "FMC-LA00_CC_N"
    set_property PACKAGE_PIN M19 [get_ports {FMC_LA00_CC_P}];  # "FMC-LA00_CC_P"
    set_property PACKAGE_PIN N20 [get_ports {FMC_LA01_CC_N}];  # "FMC-LA01_CC_N"
    set_property PACKAGE_PIN N19 [get_ports {FMC_LA00_CC_P}];  # "FMC-LA01_CC_P"  <<<<< This is an error, should be FMC_LA01_CC_P
    Mike
    Hello Mike,
    You are correct. Thanks for bringing that to our attention!
    We will make the correction and post the updated xdc file.
    -Gary
    here's a tested Zed board specific FMC connector for Alitum Designer. Includes schematic symbol, pcb footprint and 3D model.
    I used pretty much all pins, and it appears correct.
    Please use and share as you wish.
    Mike
    0 e14 Contributor over 9 years ago in reply to e14 Contributor
    It seems the Dropbox link is no longer valid.
    Could you pleas upload it again.
    Thank you.
    Link is working, just tried. But if you for some reason can't download, i can e-mail it to you.
    0 e14 Contributor over 8 years ago in reply to e14 Contributor
    I downloaded the package but it appears to be empty.
    Indeed, i will make a new lib.
