ZedBoard Hardware Design Using Zedboard for XAPP 1093
  • Subscribers 359 subscribers
  • Views 578 views
Hi all,
  I'm supposed to create a dual microblaze system and run two independent applications simultaneously on zedboard. As a first step, I'm following XAPP 1093 having a microblaze alongside ARM cortex processor which targets ZC702 evaluation board. I'm trying to map XAPP 1093 to zedboard but not knowing how to do it. I'm not sure about address mapping. Could any one please help me out as to how to update it to match zedboard? Also kindly help me if any one knows of any Xilinx app note or tutorial that targets dual microblaze system design.
    There are several dual MicroBlaze example designs on the Xilinx site (just do a search) but none that target a Zynq board that I know of.
    As per this forum post you will need to re-target the design to the ZedBoard, which has less DRAM memory than the ZC702 does:
    http://zedboard.org/content/problem-xapp1093
    XAPP 1093 is a little dated and uses the ISE tool suite. You might want to implement a similar design, targeting the ZedBoard to start with, using Vivado tools and then import the software applications from the app note and modify to match the smaller ZedBoard memory.
    Post your results for the community.
    -Gary
    Hi Gary,
    Thank you for your reply. Is that the only change that I've to make? Like modifying to match smaller DRAM memory of zed board. Yeah definitely I'll post the results once I do it.
