ZedBoard Hardware Design uart Cable is not connected to the host
  • Subscribers 359 subscribers
  • Views 409 views
hi,i am testing zedboard. When i test zedboard_CTT_Vivado_2013-4.pdf chapter 2,i have some trouble. At step 15, once i click Run ,then i get:
1. Check whether board is connected to the system properly.
2. In case of zynq board, check whether Digilent/Xilinx cable switch settings are correct.
3. If you are using Xilinx Platform cable USB, ensure that status LED is green.
i use the usb cable with the board and have install the driver. when i use terminal,the connection is ok,the the board ld10 and ld11 is off. What's wrong with me? I need help.
    sorry,i had fix the problem.i need connect another cable between host and J17.
