ZedBoard Hardware Design zed board linux design is not having .xpr file for vivado modification
  • Subscribers 360 subscribers
  • Views 522 views
satishkumar
satishkumar over 10 years ago
Hi all,
I am trying to work on "Embedded LInux handson-tutorail --ZED board", it is mentioned it uses zed board linux design.
zed board linux design.zip is not having .xpr file for vivado modification,
it is representing for .xmp file, which is not allowed to open in vivado.
Can you please provide updated "Linux hardware design" for vivado
Thanks & Regards
Satish.G
  • satishkumar
    0 satishkumar over 10 years ago
    I di dnot get any reply for this question...
    Please respond, I am in between of my project
    Thanks & regards
    Satish.G
    Could you be more specific on the tutorial you are attempting use?
    Please reply with a link to the tutorial material.
    -Gary
  • satishkumar
    ok, I am trying to work on "Embedded Linux
    Hands-on Tutorial -- ZedBoard" .pdf document avilable in "http://www.digilentinc.com/Products/Detail.cfm?NavPath=2,400,1028&Prod=ZEDBOARD&CFID=11757168&CFTOKEN=ff551d69050ab18e-46299A87-5056-0201-026A0D04772D6618"
    This dco. says get working design named as "ZedBoard Linux Hardware Design" from same link, and it is having support for "ISE 14.4" and not for "Vivado",
    how to use the same ISE design in vivado or
    there is seperate degin for Vivado?
    My understnding is Vivado is replacement of ISE design suite.
    Thanks & Regards
    Satish.G
    0 Former Member over 10 years ago in reply to satishkumar
    You will need to contact Digilent for support on their ZedBoard tutorial.
    -Gary
