ZedBoard Hardware Design Difference between AXI4 mode burst and DMA
  • Replies 8 replies
  • Subscribers 361 subscribers
  • Views 1053 views
100mokhtar
100mokhtar over 13 years ago
Hi all,
What is the difference between AXI4 with mode burst and  using the DMA??
Thank you,
Mokhtar.
    AXI4-Burst is the protocol used by DMA IP-Cores to move data in the AXI4.
    When you need an IP-Core to copy data, use the DMA IP-Core.
    On all other actions, like you have lots of data you need to do some calculations on, generate a custom IP-Core.
  • 100mokhtar
    0 100mokhtar over 13 years ago
    The problem is I created a peripheral with CIP ( AXI4 burst capable high-throughput memory mapped interface), I connected the slave of peripheral to the master GP2 of PS and its Master to the HP0 of PS (64 bits). I choose the option to generate the ISE project and template driver files of peripheral with quite the default options (added software reset). So, I don't use the DMA IP-core but my example worked with AXI4 burst mode ( the example generated by XPS worked correctly).
    So, any help?
    Mokhtar.
  • 100mokhtar
    I use just axi_interconnect to connect the masters and the salves.
    I don't understand what your problem is
  • 100mokhtar
    My problem I don't know , if the program is working properly, because I used the AXI4 bus with burst mode and without DMA
  • 100mokhtar
    More precisely, can I use only the axi bus with Burst mode and without DMA??or the burst mode with AXI4 requires obligatory DMA controller??
    The Xilinx DMA IP-Core is just an IP-Core you can use to copy data, its not required in any way.
    Before working with your own peripheral you should read ug761_axi_reference_guide.pdf
