ZedBoard Hardware Design FMC diffpair routing
  • Subscribers 359 subscribers
  • Views 529 views
I'm confused about zed boards routing of diffpair to the FMC connector. According to ZedBoard_HW_UG_v2_2.pdf, page 21:
Note, the following LPC FMC connections guidelines were followed:
CLK_#_M2C
    – 50 ohm single-ended impedance
LAbus
Diff pairs are suposed to be routed with 100Ω differential impedance, and P/N traces typically very close (for LVDS etc). The above suggest this is not the case. Can you please provide more information on the actual routing?
Mike
  • drozwood90
    0 drozwood90 over 10 years ago
    Hi there,
    The board was designed with 50 ohm single ended and 100 ohm differential pairs.
    --Dan
    Thanks Dan!
    Perhaps you should update the manual? ;)
    Mike
  • drozwood90
    Mike,
    Thanks for the feedback, I'll certainly look into making the wording a bit more clear.
    --Dan
