ZedBoard Hardware Design SDR - Use of Redhwak SDR frame work
  • Subscribers 359 subscribers
  • Views 651 views
Hi all,
     I am considering using the Avnet Zedboard and AD-FMCOMMS1-EBZ FMC Module for my
SDR implementation research project.
   The above board recommends the use of tools like Xilinx Vivado with XPS and SDK and
Mathlab Simulink for sub system design and simulation.
    I am curious to check if I can use Readhawk SDR framework for building my radio
subsystem and simulating the same instead of Simulink.
  Questions:
  1. Does Xilinx System generator support or is compatible Redhawk SDR frame work
support the autocode generation of NETLIST for the above board ?
   2. If not what kind of NETLIST does Redhawk support?
   3. Any pointers to the documentation on how to obtain the NETLIST for RedHawk SDR
frame work is greatly appreciated. I do not see Redhawk SDR active community.
   4. Do you suggest any other work around to generate the desired NETLIST for the
target board ? For example any other software etc.,
   Also, any knowledge sharing in this line is greatly appreciated.
Thank you,
    Not to discourage you from the Zed, but I'm curious, why not use a USRP or NetSDR?
    There is an active Redhawk community, but the only public manifestation of it is in the tagged articles on Stack Overflow...
    I honestly don't know anything about Zed boards however I did some quick googling and it looks like someone has an openembedded BSP layer for the system:
    http://www.zedboard.org/content/yocto-bsp
    https://github.com/milosoftware/meta-zynq
    If you can get Yocto up and running on your board, you may be able to use this:
    https://github.com/Axios-Engineering/openembedded-hawk
    to get REDHAWK up and running.  All depends on what you want to do though.  If you want to run the core framework on your board than this might be your best bet.  If you want to simply use a Zed board as a Redhawk device then there may be easier ways to go about it.
    Good luck!
    ~ sayguh
