ZedBoard Hardware Design ZedBoard - Adv7511 Configuration with VDHL
  • Subscribers 362 subscribers
  • Views 1278 views
sercan_egilmezkol
sercan_egilmezkol over 9 years ago
I want to configure the ADV7511 IC of the Zedboard with my VHDL module.
Is there any open source example for this aim?
PS-1: I checked Analog Devices examples, but cannot find any.
PS-2: My aim is by using FMC Imageon card, get the HDMI IN and run an LCD screen over HDMI again.
I can use ZedBoard's or Imageon's HDMI OUT.
For this aim I need to configure ADV7511 and ADV7611 ICs.
I have a ZedBoard. So, I will write a Test Pattern Generator which will generate 16 bit 4:2:2 YCbCr input data to the ADV7511 on the Zed.
And I will design a Configuration Module for ADV7511.
But, it will be very nice, if i can find a functioning example.
BR,
Sercan
  • sercan_egilmezkol
    0 sercan_egilmezkol over 9 years ago
    It seems that
    I will read ADV7511's HW manual & Programming Guide in detail and will make my own program.
  • sercan_egilmezkol
    http://hamsterworks.co.nz/mediawiki/index.php/Zedboard_HDMI_v2
    is a functioning example.
  • jafoste4
    0 jafoste4 over 9 years ago
    Thank you for sharing your solution Sercan!
    --Josh
    0 e14 Contributor over 9 years ago
    Did not work on my ZedBoard. Instead of getting RED/BLACK/BLUE etc... color stripe I got alternating RED/YELLOW pixels,
    BLACK -> GREY, BLUE -> WHITE/BLUE atlernating every pixel. (at least on my board and monitor)
    Did send a mail two weeks ago to the author to thank him anyway because it was the best thing I found on the net compare to other solutions, but got no reply. Given the design was written in 2014, I am loosing hope of fixing this... If you have it working under vivado, please reply here. Thanks.
