ZedBoard Hardware Design Video DMA 5.04 vs. Video DMA 6.1
  • Subscribers 352 subscribers
  • Views 149 views
Trying to create Vivado project based on Avent's "Building a Video Design from Scratch Tutorial" which is based on EDK.
Most of it makes sense but certain parameters for VDMA in both version aren't same and don't make sense.  Would like to know the difference
(especially Fsync, setting, For write channel, Gen lock master and Fsync S2MM_Fsync, but we never connnect that pin to anything in the EDK tutorial.  What should be the Fsync setting for read and write channel?)
Also, getting these warnings during the build.
WARNING: [BD 41-235] Width mismatch when connecting pin: '/processing_system7_0/S_AXI_HP0_ARID'(6) to net 'axi_mem_intercon_M00_AXI_ARID'(1) - Only lower order bits will be connected.
WARNING: [BD 41-235] Width mismatch when connecting pin: '/processing_system7_0/S_AXI_HP0_WID'(6) to net 'axi_mem_intercon_M00_AXI_WID'(1) - Only lower order bits will be connected.
WARNING: [BD 41-235] Width mismatch when connecting pin: '/axi_mem_intercon/M00_AXI_bid'(1) to net 'axi_mem_intercon_M00_AXI_BID'(6) - Only lower order bits will be connected.
WARNING: [BD 41-235] Width mismatch when connecting pin: '/processing_system7_0/S_AXI_HP0_AWID'(6) to net 'axi_mem_intercon_M00_AXI_AWID'(1) - Only lower order bits will be connected.
WARNING: [BD 41-235] Width mismatch when connecting pin: '/axi_mem_intercon/M00_AXI_rid'(1) to net 'axi_mem_intercon_M00_AXI_RID'(6) - Only lower order bits will be connected.
