ZedBoard Hardware Design Transfer data from PL to memory
  • Subscribers 360 subscribers
  • Views 747 views
e14 Contributor over 8 years ago
Hello all,
A very warm greetings to all!
I am working on a design in which PL generates packets of data, each is of 128 bits length. These packets are generated at random and  I want to store these packets at some place so as to access it later for further processing. I can use PS in a polling mode to look for the data packets, but in doing so few packets are lost by the time I reach and store them using PS. Due to this I want to have some logic in the PL with which the PL can directly store the packets in some memory.
I am using Zedboard, so the options to me are I can store these packets in DDR3 memory. I haven't used DDR3 in PL till now.
My question is how can I store these packets in memory? I also heard of FIFO memories. Which one will be the best to use in my case? Any link or user guide will be very much helpful for me.
Thank you all in advance!
Regards
  • bhfletcher
    0 bhfletcher over 8 years ago
    It looks like you got a bit of information from the Xilinx forum: https://forums.xilinx.com/t5/Zynq-All-Programmable-SoC/Transfer-data-from-PL-to-memory/td-p/802862
    You could also take a look at Avnet's Zynq Software and Hardware Development courses.
    http://www.zedboard.org/support/trainings-and-videos
    Bryan
  • tibythomas
    0 tibythomas over 7 years ago
    Greetings,
    I am working on a project where i need to send data from MicroZed through an ethernet cable. can anyone guide me with the steps of taking data and sending it through a ethernet cable and also sample program for the same?
    Thanks in advance.
  • narrucmot
    0 narrucmot over 7 years ago in reply to tibythomas
    What sort of data?  Where is it being sent over Ethernet?  How much data are you sending?
    There are probably lots of ways to achieve what you need depending on answers to these questions.
    --Tom
