ZedBoard Hardware Design ADAU1761 Audio Interface for PL
  • Subscribers 359 subscribers
  • Views 598 views
Hi guys,
based on the nice audio demo design from hamsterworks (http://zedboard.org/content/playing-adau1761-audio-codec), we have extracted the audio interface part and improved it regarding compatibility to Vivado, interface, documentation and reusability. The outcome is an IP core, that should be easy to use for your own PL designs:
https://github.com/ems-kl/zedboard_audio
have fun!
    Thanks for sharing your work with the community!
    -Gary
    I have tested the bitstreams and they are running well on Zedboard.
    However, when I generated an IP core with the source files with Vivado packager, there is an error on the IBUFG (inst name : clkin1_buf) so I replaced it with a BUFG and I was able to run synthesis. After that I created a design on Vivado 2015.1 on which I put the IP audio_top I packaged. I connected the line_in_l to hphone_l and the line_in_r to hphone_r but I doesn't hear anything when I send music on the blue jack and put a headphone on the black jack. However as I said befor, it worked when I load the bitstreams you provided.
    Do you have a solution on that problem?
    Regads,
    Ny Onintsoa
    0 Former Member over 11 years ago in reply to Former Member
    It works, I forgot to connect the valid signal. So the only problem was the IBUFG -> BUFG.
    Thank you for this project.
    Ny Onintsoa
