ZedBoard Hardware Design VDMA test
  • Subscribers 359 subscribers
  • Views 989 views
VDMA test
Any ideas on how to get the vdmatest.c to run (linux-xlnx /drivers/dma/xilinx  vdmatest.c)?  I followed the Xilinx Wiki (http://www.wiki.xilinx.com/DMA+Drivers+-+Soft+IPs) and built the vdmatest as standalone module. Using Makefile I can build and install the module with modporobe. I see it has loaded with lsmod and can see the kernel symbol in /proc/kallsyms. What I donu2019t see is any indications that the test ran (no printK to the console, dmesg or alike).  The other axidmatest seems to run OK. Any ideas on whatu2019s missing?
  • drozwood90
    0 drozwood90 over 11 years ago
    For assistance with Xilinx Designs, it is best that you contact Xilinx.
    Here is a link directly to the Embedded Vision Support Forum:
    http://forums.xilinx.com/t5/Embedded-Processor-System-Design/bd-p/EMBEDDED
    Here is one of our video reference designs, as an example of how to use the vdma driver as Avnet does it (not using vdma_test.c .
    The most recent design using the AXI VDMA core is the frame buffer design for our Toshiba camera module.
    http://microzed.org/sites/default/files/design/EMBV_TCM_Frame_Buffer_2014_4-Tutorial.zip
    Thanks for your understanding.
    --Dan
    Thank you,
    I found the problem with vdmatest.c. The drive is calling-out:
    static const struct of_device_id xilinx_vdmatest_of_ids[] = {
    t{ .compatible = "xlnx,axi-vdma-test-1.00.a",},
    t{}
    But the .dts templet is calling-out, /Documentation/devicetree/bindings/dma/xilinx/vdmatest.txt :
    vdmatest_0: vdmatest@0 {
    tcompatible ="xlnx,axi-vdma-test";
    This mismatch is keeping the vdmatest driver from loading. I ran a quick fix and now I'm seeing:
    [root@alarm dma-test]# modprobe -v vdmatest insmod /lib/modules/3.17.0-xilinx-dirty/extra/vdmatest.ko
    VDMA loaded started....
    xilinx_vdmatest: Started 1 threads using dma1chan0 dma1chan1
    dma1chan0-dma1c: terminating after 1 tests, 0 failures (status 0) xilinx_vdmatest amba_pl:vdmatest@0: VDMA test Probed!!
    VDMA loaded!
    Van
