ZedBoard Hardware Design Driving 1360x768 HDMI from Zedboard
  • Subscribers 359 subscribers
  • Views 389 views
henry10210
henry10210 over 11 years ago
Hello, I've been using 1280x1024 DVI monitor with Zedboard ever since I started (I think I also used 1680x960 early on) without a problem.  I got a new HDMI monitor, and I don't see the penguins using the same Ubuntu on Zedboard HW I've been using all along.
I posed the same question on the ADI engineer zone, but I suspect Lars (the driver author) will come back with a suggestion to stare at the kernel/drivers/gpu/drm/xilinx folder (which I am doing at the moment).  God knows how long it will take for me to debug the problem this way (although I will wind up learning a lot).
Has anyone ever driven my monitor size successfully?  Has anyone driven ANY HDMI monitor resolution?  Does anyone know if there is such a thing as a supported monitor with ADV7511 design on Zedboard?
  • albertabeef
    0 albertabeef over 11 years ago
    Henry,
    Although this is not an answer to your question, hopefully it will help you to find the answer.
    Do you know the pixel rate for this resolution ?
    Do you know the following timing details for this resolution ?
       horizontal configuration (in cycles)
          front porch ?
          back porch ?
          active region ?  1360
          sync width ?
          sync polarity ?
       vertical configuration (in lines)
          front porch ?
          back porch ?
          active region ?  768
          sync width ?
          sync polarity ?
    I often go back to a bare metal (no operating system) design to validate an interface that is not working.
    The following design is much less flexible than the ADI design, since it displays a single static video resolution.  However, it may give you more control to validate the pixel rate and timing details to drive your monitor.
       http://zedboard.org/content/zedboard-hdmi-vipp-vivado-20141
    If you use this design, you will have to modify it as follows for use with a different video resolution:
       pixel rate
       - modify the Vivado IPI block design to set the appropriate frequency (pixel rate) for your video resolution
       video timing
       - modify the IP cores in the zed_hdmi_display sub-module, to configure for your video resolution
       - modify the source code for your video resolution
          - video_resolution.c/.h : add a new video timing configuration in the vres_resolutions[] array
          - zed_hdmi_display.c : change the following lines to set for your video resolution
                  // Set HDMI output to 1080P60 resolution
                  pDemo->hdmio_resolution = VIDEO_RESOLUTION_1080P;
                  pDemo->hdmio_width  = 1920;
                  pDemo->hdmio_height = 1080;
    Hope this helps !
    Mario.
  • henry10210
    0 henry10210 over 11 years ago
    Thank you so much for the suggestions Mario, I don't have such timing information.  I wonder whether that's in the ADV7511 datasheet.  Anyway, I just tried my Qt GUI on a whim, and I see it on the HDMI monitor!  So the only problem seems to be seeing the penguins on boot.  The files you suggested will be helpful if I want to dig deep into video FW later.  Thanks again!
