ZedBoard Hardware Design XM105 compatibility
  • Subscribers 359 subscribers
  • Views 643 views
XM105 compatibility
100olivierm
100olivierm over 13 years ago
Does anyone checked if XM105 FMC module is compatible with ZedBoard ?
    0 Former Member over 13 years ago
    It sure is!
    The FPGA Mezzanine Card (FMC) interface is a ANSI/VITA standard.  You can read about it here:
    http://www.xilinx.com/products/boards_kits/fmc.htm
    and here:
    http://en.wikipedia.org/wiki/FMC_%E2%80%93_FPGA_Mezzanine_Card
    Since it is a standard, and the XM105 Debug card is a Low Pin Count (LPC) FMC card, it plugs right in and you are good to go.  To map pins correctly, you can reference the Zedboard schematic and the XM105 schematic.
    Here is the landing page for the XM105 board:
    http://www.xilinx.com/products/boards-and-kits/HW-FMC-XM105-G.htm
    You can purchase the board from Avnet Express here:
    http://avnetexpress.avnet.com/store/em/EMController?langId=-1&storeId=500201&catalogId=500201&term=HW%252DFMC%252DXM105%252DG&x=14&y=6&N=0&Ne=100000&action=products
    I will see if I can spend some time and get a UCF file put together for the XM105 and the Zedboard and post it.
