ZedBoard Hardware Design Linux on AMPIRE10 Kit
  • Subscribers 359 subscribers
  • Views 334 views
400garrison
400garrison over 7 years ago
Is there any evaluation code for using the 10-inch dispay kit (AES-ALI3-AMPIRE10-G) with the Zynq running Linux? I have looked on the github and can only find what you would call ‘bare metal’ code example projects.
  • zedhed
    0 zedhed over 7 years ago
    Hi 400garrison,
    We do not have anything publicly available for this since there is little that we can do to support a design which would effectively change every Kernel release.
    If you want to PM me, I can share with you a 2015.4 design build on a 4.0 kernel build which serves as a proof-of-concept on how to attach the display direct to a Linux frame buffer and pipe a Qt windowing application to it.
    Keep in mind that this design would be for reference only since there are not enough resources to support it ongoing.
    Best Regards,
    -Kevin
