ZedBoard Hardware Design top entity VHDL code for partial reconfiguration
  • Subscribers 360 subscribers
  • Views 475 views
I am trying to apply simple example on ZED Board for partial reconfiguration. I synthesis my vhdl code in  XILINX ISE and used to NGC file of the top entity in the PlanAhead but the modules didn't appear in the Synthesized Design here is my vhdl code :
entity TopEntity is
    Port ( Switch : in  STD_LOGIC_VECTOR (7 downto 0);
           LED : out  STD_LOGIC_VECTOR (7 downto 0));
end TopEntity;
architecture Behavor of TopEntity is
component  SwitchLedController is
   end component;
begin
partial: SwitchLedController port map(Switch, LED);
end Behavor;
  • narrucmot
    0 narrucmot over 11 years ago
    The ISE design flow for Partial Reconfiguration has been deprecated and has been replaced by Partial Reconfiguration using the Xilinx Vivado tools.  Please see Xilinx UG947 (http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_4/ug947-vivado-partial-reconfiguration-tutorial.pdf) for a useful design example and Xilinx UG909 (http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_4/ug909-vivado-partial-reconfiguration.pdf)for a thorough description of the design flow using Vivado.  You may also be interested in the Avnet XFest 2014 course "Partial Reconfiguration in Zynq" (http://xfest2014.com/course/partial-reconfiguration-zynq%C2%AE-7000-all-programmable-soc).
    0 Former Member over 11 years ago in reply to narrucmot
    Ok thank you I will try the design flow using Vivado tools.
