ZedBoard Hardware Design ZedBoard Base Linux Design
  • Subscribers 360 subscribers
  • Views 477 views
Does anyone know if there exists a base Vivado design for the ZedBoard that can be used to run the gui linux (w/display output, usb, and ethernet). I'm trying to use a custom IP core that can be called by a linux application to run on ZedBoard but I need a system to integrate the ip core into.
  • zedhed
    0 zedhed over 11 years ago
    Hi BluePAZ,
    It sounds like you are looking to run full Desktop Linux on your ZedBoard.  For that, probably the best place for you to start would be with our Ubuntu Desktop Linux which can be found on the Reference Design/Tutorials page for ZedBoard.
    http://zedboard.org/support/design/1521/11
    That tutorial is based upon a Vivado 2013.4 hardware design that is provided by the folks at Analog Devices.  Within that hardware design, you will find support for the ADV7511 HDMI transmitter chip as well as on-board USB host controller and Ethernet.  Once you get that up and running on your ZedBoard, that is a good hardware platform to start from to integrate your own IP into.
    -Kevin
    0 e14 Contributor over 11 years ago in reply to zedhed
    Hi Kevin,
      Thank you for your reply and the link to that reference design. I will try that!
    Hello guy,have you finished this project? May you help me?
