ZedBoard Hardware Design Zed Board XADC Auxiliary Channel
  • Subscribers 361 subscribers
  • Views 889 views
jayasankarvn
jayasankarvn over 9 years ago
How do you access the 16 auxiliary channels of XADC ? Can I use the existing I/O pins as auxiliary inputs ? I couldn't find any options to change the sites of auxiliary channels. Should I use an FMC breakout board to access all analog channels ?
  • jafoste4
    0 jafoste4 over 9 years ago
    Hi Jay,
    Please refer to this post
    http://zedboard.org/content/xadc-reference-design
    --Josh
  • jayasankarvn
    0 jayasankarvn over 9 years ago in reply to jafoste4
    I referred almost all possible documents. But one thing is not clear to me. If I use Vp/Vn or vauxp0/vauxn0 or vauxp8/vauxn8, the external analog signals can be connected through the pins in xadc header. If I want to extend the auxiliary channel number, where do i connect the analog signals ? Should I use an fmc break out board to access those ? Or can I convert the Pmod I/Os to auxiliary channels ? Please do reply. I've been spending time for last two weeks to clear this doubt.
  • drozwood90
    0 drozwood90 over 9 years ago
    If you are using the signals as differential, you only get 8.  If you use them as single ended, the _N is the second analog in.
    --Dan
  • jayasankarvn
    It is clearly mentioned in the user manuel that total 17 analog differential channels can be connected. But using xadc header I can connect only 3 differential signals. My doubt is, how to connect those remaining auxiliary channels ? How do I access the pins ?
  • jafoste4
    Hello Jay,
    Please ask your question over at the digilent forum as they are the main point of contact for educational support.
    Josh
