ZedBoard Hardware Design PL to PC direct communication
  • Subscribers 361 subscribers
  • Views 473 views
soha
soha over 9 years ago
I have loaded a Xillinux OS on the Zedboard and I'm currently trying to implement a program trace system in the HW. Specifically, the main idea is to generate traces for objects of interest (i.e. instruction flow) through the Coresight functionality, and download the trace off the FPGA so that I can run some further analysis in my own software environment.
AFAIK, traces generated by the 'Coresight' can be exported to custom PL and some analysis/computation can be performed there on-chip. However, this doesn't fit my scenario. So I have two questions,
(1) Is there any way that my PL can further offload the trace to an external PC so that I can perform analysis/computation in my own software environment?
(2) For my objective described above, is this (i.e. PS --> Coresight trace --> PL --> external PC) the correct way to implement the trace system? Is there any other better option?
Thanks.
  • jafoste4
    0 jafoste4 over 9 years ago
    Hello Soha,
    I am going to ask that you ask any further questions over at Digilent as they are the main point of contact for educational support.
    https://forum.digilentinc.com/
    This post should help you with you issue http://zedboard.org/content/enable-arm-core-tracing
    --Josh
  • soha
    0 soha over 9 years ago in reply to jafoste4
    Hi Josh,
    Thanks for your advice. I will check it.
