ZedBoard Hardware Design Using PMOD JC and JD as Single Ended
  • Subscribers 359 subscribers
  • Views 811 views
We are trying to use PMOD JC and JD as single ended instead of differential.  We have changed the 0 ohm resistors on the ZedBoard to 200 ohm resistors like in the JA and JB PMODs  We are using the Vivado tool suite.  Whenever we write to JC1_P (or JD), JC1_N toggles.  When we write to JC1_N, nothing happens and when we write to JC2_P then JC2_N toggles.  What is the proper way to use the PMOD C and D as single ended??
    You should be able to use the ZedBoard JC and JD PMOD interfaces in a single ended fashion as you describe. Make sure that your constraints file is correct and that you are probing the correct PMOD pin.
    -Gary
    how can i work whit JA and JB whit together ?
    0 Former Member over 10 years ago in reply to Former Member
    Look at the response to one of you other duplicate posts on this subject for an answer: http://zedboard.org/content/adc-and-dac-pmod
    Please do not post the same question to multiple threads or forums on the site.
    -Gary
