ZedBoard Hardware Design Reference design for Zedboard and AD-FMCOMMS2-EBZ
  • Subscribers 359 subscribers
  • Views 813 views
Is there a reference design with Verilog/VHDL code and C code for the Zedboard with AD-FMCOMMS2? (preferably with Vivado, but ISE is fine too, if that works).
I am looking to build an RF baseband on FPGA on the Zedboard and use it as an access point, but am unable to find a reference design that I can use as a starting point. Any help you can provide will be much appreciated.
Thanks!
    There is a reference design for ZedBoard + FMCOMMS2 under ISE 14.4 that is available here:
     http://wiki.analog.com/resources/eval/user-guides/ad-fmcomms2-ebz/reference_hdl
    There is a Vivado 2013.2 version that will be released soon, but no firm date yet.
    -Gary
    0 Former Member over 12 years ago in reply to Former Member
    Thanks. I will start working with the ISE version, and let you know if I have questions. Look forward to using the Vivado version when it is out.
    I am using the reference design from https://github.com/analogdevicesinc/fpgahdl_xilinx.git (using git clone) with ISE 14.4 (64 bit RHEL 6 version). I am using the procedure to generate xilinx netlist files from xco (from http://wiki.analog.com/resources/eval/user-guides/ad-fmcomms2-ebz/reference_hdl). When I import "cf_lib/edk/pcores/adi_common_v1_00_a/netlist/ad_dds_1.xco", ISE 14.4 crashes with the following message:
    "FATAL_ERROR:GuiUtilities:Gui_Clip_ApplicationBase.c:369:1.30 - No index entry
       for empty element ID. This application has performed an illegal operation and
       must be shut down.  Process will terminate. For technical support on this
       issue, please open a WebCase with this project attached at
       http://www.xilinx.com/support."
    Do you have recommendations to address this problem?
    Thanks.
    I am sorry - I meant that ISE 14.4 crashes when importing "cf_lib/edk/pcores/adi_common_v1_00_a/netlist/ad_dcfilter_1.xco"
