ZedBoard Hardware Design Set the frequency of IP in PL
  • Subscribers 360 subscribers
  • Views 528 views
100mokhtar
100mokhtar over 13 years ago
Hi all,
I used the AXI-Lite bus to implement my IP in the PL party. I synthesize the IP with the settings by default.
After the synthesis I found 104.5 MHz in the summary of PlanAhead . So, it's the frequency of the AXI-Lite bus??
Another question please, how can I fix the frequency of bus used from the XPS ???
Thank you,
Mokhtar.
    You need to apply a period 9timing) constraint.  If you wish to operate the logic at 100 MHz, then you require a 10ns period constraint.
    To apply constraints, you need to read about timing:
    http://forums.xilinx.com/t5/PLD-Blog/Timing-Constraints-Part-2-of-5/ba-p/59595
    (there are 5 parts to this blog)
    Austin Lesea,
    Principal Engineer,
    Xilinx
  • 100mokhtar
    0 100mokhtar over 13 years ago
    Hi Austin,
    Thank you for your reply.
    If I set the CLK from XPS Xilinx, is it correct?
    Thank you,
    Mokhtar.
