ZedBoard Hardware Design Zedboard can not setup
  • Subscribers 359 subscribers
  • Views 268 views
when power is on ,the output of the MAX8086 is 3.4V and the input of the MAX 8086 becomes 4V .What is the matter?
    I assume you mean the MAX8686 device, as there is no MAX8086 on the ZedBoard.
    Is this a new board or a board that has been working and now has a problem?
    The input voltage should be 12 VDC. The most likely source of the problem is your power supply. If you have access to another ZedBoard 12VDC power supply give that a try.
    -Gary
