ZedBoard Hardware Design Echo Server
  • Subscribers 362 subscribers
  • Views 1007 views
Echo Server
isaleminik
isaleminik over 9 years ago
I'm new to the forum. I'm having problem running Echo server example with Vivado 2016_3 on Zedboard. The project loads correctly and I see the correct messages on serial port i.e. "  TCP echo server started @port 7", but from PC window application I can't do a PING. I also set a static IP address of the board, but no luck.
  • bhfletcher
    0 bhfletcher over 9 years ago
    Did you also set your PC to a static IP address on the same subnet as the board IP?
    Bryan
  • isaleminik
    0 isaleminik over 9 years ago in reply to bhfletcher
    Thank you Bryan. The problem is resolved and it was due to autoconfiguration IP4 setting being enabled in my network. When I had this feature disabled by my IT, I'm able to ping the board.
  • anna51
    0 anna51 over 9 years ago
    I have exactly the same issue. Pardon my ignorance but how do I set my PC to a static IP? I'd be grateful for any help.
    Anna
  • jafoste4
    0 jafoste4 over 9 years ago
    Hi Anna,
    http://kb.netgear.com/27476/How-to-set-a-static-IP-address-in-Windows?cid=wmt_netgear_organic
    --Josh
