ZedBoard Hardware Design How to swap out marvell PHY in linux?
  • Subscribers 359 subscribers
  • Views 431 views
Hi
I need to swap out the Marvell 88E1518 PHY on the ZedBoard with a switch, a Marvell 88E6352 PHY. The Driver for this switch is found on u-boot-xlnx/drivers/net/phy/mv88e6352.c
How do I compile this driver and do the swap so I can use the switch with linux?
    Are you planning to physically swap the devices on the ZedBoard or add this via the FMC connector or is this a custom board?
    -Gary
    Hi, this is a custom board. The tutorials I found does not go in to detail on every step for a custom board.
