ZedBoard Hardware Design Programming Zynq with Matlab/Simulink
  • Subscribers 359 subscribers
  • Views 578 views
Hey,
i tried to do the example on mathworks (http://www.mathworks.de/de/help/hdlcoder/examples/getting-started-with-hw-sw-codesign-workflow-for-xilinx-zynq-platform.html). Everythinks works fine until i generate the software interface module in the workflow adviser. The Error is that there is a problem with the originale devicetree and a file that could not be open or is missed. When i skip this step and programm the FPGA with the generated Code, the Linux-System on Zedboard seems to be shutdown. In this case the FPGA is programmed but i cannot connect anymore to the Zedboard. Do you have any idea what goes wrong?
Thanks and regards
Jan
  • mbrown
    0 mbrown over 12 years ago
    It's possible something has corrupted your devicetree.  Strange, but possible.
    Try using the 'targetupdater' command at the MATLAB prompt.  It will accomplish the following:
    - Invokes wizard to setup dev boards for Zynq workflow
    - Copies latest Linux image and devicetree to SD card
    - Copies latest driver (.ko) to SD card
    - Sets up network interface over ethernet from host
