ZedBoard Hardware Design impendance problem of Zedboard via FMC connector
  • Subscribers 359 subscribers
  • Views 902 views
dagouyi
dagouyi over 8 years ago
Hi, I am the Ph.D student of Stevens Institute of Technology. Our group currently try to build our own a Time-to-digital converter (FMC) that will interact with the Zedboard via FMC connector. This TDC will output LVDS signals, therefore, we plan to use bank 34,35 differential signals. I have a question about the circuit design.
The Hardware User Guide data sheet mentioned that the LPC FMC requirement is a 50-Ohms impedance single ended.  I am not quite sure what that means. Does that mean we need to connect a 100-Ohms impedance between our differential signals? Or the 100-Ohms impedance is already the load out from the FMC and we just need to hook up our differential signals directly to the FMC? Thank you.
  • jafoste4
    0 jafoste4 over 8 years ago
    Please refer to these links.
    https://www.4pcb.com/controlled-impedance/
    http://www.omnicircuitboards.com/blog/bid/337171/Understanding-PCB-Manufacturing-Impedance-Control
    https://www.quora.com/What-does-someone-mean-when-they-refer-to-an-impedance-controlled-PCB
    The exercise of putting in your single ended 50-Ohm impedance or differential 100 Ohm impedance is done by your layout expert.
    --Josh
